Reed Spacers
Hockey390
search for it
Oooo thats never a good reply. :angry:
Reed spacers will increase the crankcase volume. Increased crankcase volume will cause a "mellower" powerband hit. Do you want a mellower powerband ? I wouldnt say you lose any HP, it just smooths out the powerband hit. Some guys use the spacers when they're running aftermarket carbs, on some aftmkt carbs the float bowl on the one carb will not clear the little clutch arm that sits under the carb, the reed spacers move the carbs back, clearing the clutch arm. The real question is....... is "mellower" a real word ?? :ph34r::ph34r::ph34r::ph34r:
I had them, took them off, rode and put em back on. I can honestly say it did hit harder without them. Not a huge hit but a somewhat noticable difference. I have kept them off, same with my boost bottle. I didnt notice ANY difference with or without the bottle and opted to take it off because it kept working its way out of the boots for the intake and I was concerened the motor would some some sand/dirt.
