Welding The Crank?
Big Mike NY
I believe the stock cranks are just welded on the outside and aftermarket cranks are welded inside and out. The reason for welding the cranks is because they tend to seperate or twist over time. As a precaution the crank should be welded at any time with or without modifications. Some people that is the first mod they do as soon as they leave the dealership.
With a aftermarket head,pipes, and just basic hopup stuff, you prolly won't need to weld crank. If you take it out and drag race it, even stock, where you rev it to the limet and drop the clutch, then its a real good idea to weld it. This is just my opinion you should weld the crank when you get your motor to putting out 55 plus hp, or if you are in there doing some work, it is good insurance.
