I installed bigger Wiseco Pistons 66mm Diameter, install FMF pipes on the exhaust and also the tors delete kit. I live in el paso, TX with 3700 feet above sea level. I haven't be able to set my carbs with the correct main and Pilot jets.
The banshee does not run good on idle and neither when throttle. I have seen better conditions when I replace jets but I cant be able to find the correct sizes for each (pilot and main).
Please help!
