kmaster9751 Posted November 28, 2022 Report Share Posted November 28, 2022 hey guys! went out on the shee today and unfortunatly blew up the top end at least i hope thats all thats wrong havent opened it up yet but i just did a bottom end job on it and put in a hot rods stock stroke crank so hopefully its still okay... anyways i wanna rebuild it with the 370cc Athena big bore kit and wanted some feedback on what jetting i should run elevation: 1200 stock carbs with 260 mains stock pilot (i forget what size) toomey t5 pipes k&n pod filters vforce4 reeds i believe im running 0 degrees timing ill have to check my timing plate when i get into it but any info on what you guys think i should be running with the new top end would be greatly appreciated!! Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 28, 2022 Report Share Posted November 28, 2022 Why Athena? Driveline would be a lot better choice. You would be about 280 main and 27.5 pilot. Quote Link to comment Share on other sites More sharing options...
kmaster9751 Posted November 28, 2022 Author Report Share Posted November 28, 2022 i thought athena was a good brand to go with but ill check out driveline as well. tore it down today and actually found that the right piston rod is seized as well i can only assume because of the grenading of the right cylinder..... looks like a full tear down and rebuild is in my future...... Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 29, 2022 Report Share Posted November 29, 2022 Get it all here. https://drivelineperformance.com/ Quote Link to comment Share on other sites More sharing options...
