135psi Right And 140psi Left
dittmer
Compression wise you are fine. You can kick a little harder on one and get different numbers. Checking the compression doesn't tell you the condition of your piston skirts though. If you've never changed your rings, and your compression numbers are that good, your skirts probably aren't worn either. I'd leave it alone. Sounds to be strong.
