I just bought a K&N filter brand new - model YA-3502 for my 2001.
I also bought a pro-flow adapter plate off ebay. When I place the filter over the oval flange of the adapter plate there is way too much space between the flange and the filter (> .5").
I tried cranking down the clamp to close the gap but after a while it starts to pinch the filter edge and the connection still isn't tight.
So I start thinking that maybe I have the wrong size - either filter or adapter plate.
The K&N model number checks out - it even lists "Banshee 87+" on the box. The adpater plate I have no idea.
Anyone experience this problem?
What size should the adapter plate be?
thx
You probably got a pro design filter adapter made for a foam filter not the K&N. These things happen when you order stuff off ebay (say it's one thing and it turns about being something else).
You have the right filter YA-3502 K&N but you may have the wrong plate.
The filter does have a round opening and the plate is oval but I do not know the measurements on the plate.
You might contact Noss Machine and maybe David will give you some info.
  • 2 weeks later...
Just to follow up.
It was the wrong plate.
Tried to replace it with a new one.
I ended up running out of time for the new years trip, so I just cut the stock filter cage, removed the foam from the plastic plate, bolted the plastic plate to the box a la the pro-flow and clamped the k&n to the plastic lip.
Worked great. I may forget the pro-flow all together.
thx
