i already have pipe kit. i am wanting to ride on the hatfield mccoy trails and they require spark arresters. toomeys are $150 per set :o and i was looking for a cheaper way out :D
Toomey sells spark arrestors that fit the ends of the silencers on his website. If you can find the model number some where you might be able to get them else where for cheaper. You could also just buy a hush kit v2.5 and be done with it.
If you have you're old silencers you can cut about an 1-1/2" off the head pipe end and use those. I always used mine at areas that require a spark arrester and they work good. Alot cheaper too!
