Vito's +4 Degree Keys
i have heard some good and bad things about the vitos degreekey, i have heard some people say there good and they a noticable power and what not, but i have heard more people say that they are not worth getting because the sheer off waredown and will basicly be a stock key after a while. and i was just wanting to hear what you all have to say about them.. thanks, jayare
They will shear off if you don't use a strap wrench around the flywheel and use an impact wrench. I have never saw one wear down. I have the vito's which was $25 and i beleive alba has one for $10 or $12. Or you can modify your timing plate for free.
could you go more into detail about this, I am getting ready to install mine and want to do it the right way. What would be the wrong way to install the key..
the keys are only as reliable as the installation.I made a flywheel holder out of some 1/8"x1"x24"flatstock and some longer 3/8 bolts..I used the exsisting holes in the flywheel and spaced 2 of them out on the flatstock.Drilled and tapped 2 holes and voila.I ground the threads off of the bolts and made them smooth,so they wouldn't marr the holes.
Took me 1/2 hour and I was able to torque the flywheel properly.Betteer than paying 30 some bucks.I 've used it probably 3 times,so it was worth the time spent.
Just make the flatsock long enough so the it will touch the ground and secure itself.That way you don't have to hold it while your torqing the nut.
