Tag05 Posted August 28, 2022 Report Share Posted August 28, 2022 So I bought this banshee from a friend, needed a new top end so I put a new top end, reeds, intake boots, rebuilt carbs, Cdi box, spark plugs it has spark, it’s getting fuel, the tors is already deleted , I already ohmd out the stator, the key is already bypassed It sounds like it wants to fire occasionally but never will is there something I’m missing Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 28, 2022 Report Share Posted August 28, 2022 oem/ genuine: cdi, cylinders, carbs? carb bowls on correct carb, crossover tube on, slides in correct, rats nest in pipes, pick up gap, good ground...,... Quote Link to comment Share on other sites More sharing options...
Tag05 Posted August 28, 2022 Author Report Share Posted August 28, 2022 Oem cylinders .40 over Oem carbs 30 pilot, 300 main at 150 ft elevation 1 1/2 turns out on air/ fuel screw, oem Cdi and also have a brand new Vito’s Cdi carb bowl with starter jet is on the left carb with chock nob, cross over tube is on nothing in the pipes, checked ground finally got it to run for a few seconds with starting fluid and would rev out but quickly died out I was thinking to go make a leak down tester? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 28, 2022 Report Share Posted August 28, 2022 If it'll run on spray, i'd look at why you're not getting fuel to cyl's next. And yes always do a leakdown test after topend. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted August 28, 2022 Report Share Posted August 28, 2022 The air jet and the pilot jet are externally identical, Be sure the air jet (in the air horn) is a 1.6 (much bigger than a pilot), that is what draws air to draft fuel on start up. 1 Quote Link to comment Share on other sites More sharing options...
Tag05 Posted September 10, 2022 Author Report Share Posted September 10, 2022 So i did a leak down test and I had a air leak at the base gasket. Fixed it. Holding 5 psi now. Still same issue She wants to fire, I can hear it, but never will Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted September 10, 2022 Report Share Posted September 10, 2022 You've got to find out why its not getting fuel Quote Link to comment Share on other sites More sharing options...
silversmg45 Posted September 11, 2022 Report Share Posted September 11, 2022 Are you 100 percent sure you put gas in it and the petcock is flowing fuel? Quote Link to comment Share on other sites More sharing options...
Tag05 Posted September 12, 2022 Author Report Share Posted September 12, 2022 Yes it is getting fuel the spark plugs are wet ive tried putting back in the 25 pilot again to see if maybe it’s getting to much fuel but that hasn’t made a difference Quote Link to comment Share on other sites More sharing options...
silversmg45 Posted September 13, 2022 Report Share Posted September 13, 2022 What is compression on the cylinders? Quote Link to comment Share on other sites More sharing options...
Tag05 Posted September 13, 2022 Author Report Share Posted September 13, 2022 150 per cylinder Quote Link to comment Share on other sites More sharing options...
gusto Posted September 14, 2022 Report Share Posted September 14, 2022 What pipes? Has it been ported? What’s the condition of the reeds? Quote Link to comment Share on other sites More sharing options...
Tag05 Posted September 14, 2022 Author Report Share Posted September 14, 2022 Reeds are brand new vforce 4 bills expansion chambers fmf turbine core 2 no port vitos superstock pistons so I just made some progress the original Cdi is bad I had checked spark again for prob the 50th time and realized that it wasn’t producing enough so I thru on the Vito’s cdi and plenty enough spark bike started. Now I just need to figure out the correct jetting i believe I just had was jumbling to many problems that made it all clustered Between bad cdi ,air leak at the base gasket , and the fact that I have just bought this and haven’t actually had it run smoothly for me to start a base line with 1 Quote Link to comment Share on other sites More sharing options...
silversmg45 Posted September 14, 2022 Report Share Posted September 14, 2022 Nice. Good progress Quote Link to comment Share on other sites More sharing options...
