Running Blaster Pistons
TheNewGuy
hey,
i read on someones signiture about boring .100 and running blaster pistons...wondering if anyone has heard of this a lot or if it's just a custom thing....would i need to get a bigger crank or true/weld it?....
any REAL posts would be greatly appriciated
thanks ahead of time
Mike
p.s. - pics would be awesome too
i squished mine with my foot. to 14.93784758375484 degrees and it worked perfect with my dual blaster cranks i jb welded one of my blaster cranks so one went backwards so i got reverse now in cylinder and i use the other one to go foward works good now it was just dificult to put the muffler bearings in backwarks the the exhuast would go the right way.. :blink::ph34r:
Blaster pistons from what I know, are usually ran with long rod applications. The wrist pin is higher than a stock banshee wrist pin, which keeps the piston in about the same place in the bore that it was before, execpt you get the longer connecting rod to ease the side pressure on the skirt of the piston.
I bought a set of polished cylinders that are running blasters pistons,and they like 6mm coming to the top of the cylinders,so if you run them i guess you would have to have a 6mm crank for them to work right,the blaster pistons are .30 over the cylinder bore is .080 over.
