Luiskckemc Posted August 3, 2022 Report Share Posted August 3, 2022 I have a banshee and I want to put uni pods but what do I do with the reservoir ??? Can any one help me plzz Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 3, 2022 Report Share Posted August 3, 2022 Think jds sells a bracket Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted August 4, 2022 Report Share Posted August 4, 2022 You can also cut your air box, leaving the rear frame mounting tabs and the reservoir mounting location…. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 4, 2022 Report Share Posted August 4, 2022 Or sell it for $100 buy $25 jds bracket & pocket $75 Quote Link to comment Share on other sites More sharing options...
Qliphoth Posted August 4, 2022 Report Share Posted August 4, 2022 on the stock pipe at the right side, i noticed some white residues. after i parked the Shee, i heard a hiss and then i saw some fluid dripping out of a hose directly onto the hot pipe. it was a hot day with more than 35° celsius and the engine cooling probably wasn't ideal that day. is this coolant and the hose is part of the reservoir tank? i forgot it. the hose leads under the fuel tank and ends nearby the ignition coil. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted August 4, 2022 Report Share Posted August 4, 2022 If it was coolant, then yes. you also have 2 vent hoses for trans, that "T" together & run up also, so Quote Link to comment Share on other sites More sharing options...
Qliphoth Posted August 4, 2022 Report Share Posted August 4, 2022 that means the engine ran too hot or what? i think i need to ride that thing a little more carefully during the summer period. Quote Link to comment Share on other sites More sharing options...
