my mods are (DMC pipe for fun) ported wisco pistons .80 head 20cc domes 4mm strocker v-force reed 2 external air filters (i have a set of 35mm carbs should i use them but the thing is that they dont performe will on wheelies dyna sf i would love to stick to my stock carbs for fun but i just changed my top end cuz the pistons has jamed to lean i was running 350 mains i have a set of 390 400 410 main should i use them or is it gona be to rich
Throw the 400's in and go from there. Better to start rich and work down....run it wot in 6th gear for 5-10 seconds, pull the clutch in, shut it down, pull the plugs...black is rich, brown is perfect, tan or white is lean...
20cc domes.......what are you running for compression??? what octane fuel?? what did the pistons look like?? were they melted toward the exhaust or holes in the top, center of the pistons??
