Rz350 Tranny
snowprophet1
I am going to use my RZ tranny in my RZ Shee. I will let you know in about a month or 2 on how it preforms. Just got last engine peice last week so time to put together.
I will be using the RZ-Shee for mainly drags so the longer legs should help.
Rabbit
i have resurched this as i have an rz tranny sitting on the shelf at home. I have basically concluded that if you ride in 5th and sixth alot on your banshee then you would benifit from it. If you ride your banshee in 4th and lower most then stick with the banshee. Rz box would be really benifical if you where running tall gearing on the shee due to the close ratio in the top 3 gears.
RZ350 ----- Banshee
1st - 2.57:1 ----- 2.461:1
2nd - 1.778:1 ----- 1.812:1
3rd - 1.318:1 ----- 1.500:1
4th - 1.083:1 ----- 1.250:1
5th - 0.962:1 ----- 1.045:1
6th - 0.889:1 ----- 0.875:1
