Banshee0028 Posted December 27, 2003 Report Share Posted December 27, 2003 I would go w/ a 16/41 gear w/ 18" tires.....14/41=stock 14/41 for piped shees w/ 22" tires 15/41 for piped shees w/ 20" tires 16/41 for piped shees w/ 18" tires Thanks Blue and Banchetta...I just ordered the 17 already so will have to try it and see how it works.....If it don't pull hard enough, I will go down from there (16/15) ....Will see what happends....This will be with the 18's of course Will post the results......Later, Quote Link to comment Share on other sites More sharing options...
Blue Duece Posted December 27, 2003 Report Share Posted December 27, 2003 I would go w/ a 16/41 gear w/ 18" tires.....14/41=stock 14/41 for piped shees w/ 22" tires 15/41 for piped shees w/ 20" tires 16/41 for piped shees w/ 18" tires Thanks Blue and Banchetta...I just ordered the 17 already so will have to try it and see how it works.....If it don't pull hard enough, I will go down from there (16/15) ....Will see what happends....This will be with the 18's of course Will post the results......Later, your going to have to notch the inside of your case for the 17, and you cant run a case saver..... Quote Link to comment Share on other sites More sharing options...
sandbanshee1818 Posted December 27, 2003 Author Report Share Posted December 27, 2003 What gear combo would work best for the dunes? Bikes piped, ported, etc etc Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted December 27, 2003 Report Share Posted December 27, 2003 I ran a 13/42 At StAnthony and I am going to gear 13/41 this next ride. Some riders like the 14/44 too. 3.15: 1 ratio is good starting point. So I was 3.23:1 that was 13/42. 3.1538 is with 13/41. 3.1428 is with 14/44 so you see there about the same. Where do you ride sandbanshee1818? Quote Link to comment Share on other sites More sharing options...
