Correct domes?
Hi I purchased a banshee second hand was told it was a stroker motor. Just pulled the stock head it has 795 65mm wiseco pistons. The jugs appear to be aftermarket as they say fmf on the side. Problem I’m having is when piston is at tdc the only thing coming out of head is the domed part of piston none of the side wall comes out I was under the assumption a small amount of the side wall was suppose to come out of the cylinder as well with a stroker . No spacer. Stock head didn’t appear to have any work to it either. Question now is am I suppose to run stroker domes or just stock domes just don’t want to ruin anything . I’m switching to a chariot head . Thanks for help
Edited by Critchy87
