caleb90 Posted June 11, 2022 Report Share Posted June 11, 2022 So had my jetting dialed in most the way last year, just ran fat on the bottom even with 27.5 pilots. I assumed the needles and draft tubes were wore causing a rich condition. So i just replaced the slide needles and draft tubes with new oem, put 30 pilots back in. Air screw 2 turns out. Stopped and got 100ll today filled it up and wtf. Idles on th pto side only unless i choke it some, the the mag side will kick in for a bit. Took mag cab off, went through it again and same issue. Compression is at 125psi mag and 123 pto. My only thought left is to swap carb parts to see if the problem follows. Just seems odd as the only thing new is fuel, pilot jets and needles + draft tubes. Quote Link to comment Share on other sites More sharing options...
dano3 Posted June 11, 2022 Report Share Posted June 11, 2022 try again with 27.5?? You said it ran fat with 27.5 but you went up a size? crossover tube connected between both carbs? Also make sure carbs are synced at idle and off idle. Quote Link to comment Share on other sites More sharing options...
caleb90 Posted June 11, 2022 Author Report Share Posted June 11, 2022 Yes ran fat with 27.5 pilots before. But when i bought the machine it had ingested alot of sand. With the motor work i have it should need a 30 pilot, so i assumed the needle and draft tubes were wore bigger due to dirt. So i replaced all that with oem new. It acts like its running lean now at an idle, yes carbs are synced and the choke cross over is connected. Quote Link to comment Share on other sites More sharing options...
caleb90 Posted June 11, 2022 Author Report Share Posted June 11, 2022 So had a dumb moment. Went out this morning to swap jets and reclean carbs. Every thing was spotless or so i thought. The pilot jet in the side i was having issues, had a wad of fuz in it from the new petcock i put in. Put all back together and ran as it should... Good news is i was right about the needles and draft tubes being wore. As now it needs the 30 pilots in it, currently at half turn out, still kinda fat on the bottom Quote Link to comment Share on other sites More sharing options...
