Help Again!
KEVPOPPAPUMP
What is the special tool that I need to remove the clutch arm pilot bearing in the top half case?
I have been pounding for hours and the race is still not budging. The only thing that I have managed to do is really mess up the clutch arm bore's smooth finish with screwdriver pitts and gouges :angry:
Use a dremel and cut the race. Don't bother trying to rip it out as your more likely going to mess something up. Once you grind down almost all the way through the race you can normally just twist it and it should split and fall right out.
