q8bizkit78 Posted December 19, 2003 Report Share Posted December 19, 2003 the kick start handel is jamed it wont move i was trying my shee and is stoped Quote Link to comment Share on other sites More sharing options...
ScreaminShee01 Posted December 19, 2003 Report Share Posted December 19, 2003 this happened to me... what happened is my piston skirt broke off and fel down jammed my crank and derbis felldown under my crank in the case.... not pretty but eay fix.. just rip the motor open split the cases and clean clean clean.... thats what i had to do maybe you have a different problem... pull your pistons and see if thats what happened Quote Link to comment Share on other sites More sharing options...
Dextreme Posted December 19, 2003 Report Share Posted December 19, 2003 If you are saying your kickstarter won't swing out, remove it, take it apart and clean out the rust, dirt and crud. Relube with silicone lube or graphite lube and reassemble. Quote Link to comment Share on other sites More sharing options...
ScreaminShee01 Posted December 19, 2003 Report Share Posted December 19, 2003 yeah like dex said... is it jammed in like in the normal riding postion; it wont swing out, or the motor wont turn over? Quote Link to comment Share on other sites More sharing options...
