375hp banshees Posted June 1, 2022 Report Share Posted June 1, 2022 Cylinders?Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 1, 2022 Author Report Share Posted June 1, 2022 I don't think it is them, fresh engine and it cleans up as fuel runs out / air is forced into the carbs. If I can't figure it out I'll pull the head and check them out. Pistons look clean through the intake and exhaust thoughSent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 1, 2022 Report Share Posted June 1, 2022 What cylinders are they ...who ported them... what did they suggest for jets? Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 1, 2022 Author Report Share Posted June 1, 2022 Stock jugs Eric Gorr woods port. I haven't reached out to him regarding jetting as it was running well, thought I had it pretty close until whatever this is happenedSent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted June 2, 2022 Report Share Posted June 2, 2022 Pull the stator cover and check the timing, and flywheel key way Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 2, 2022 Author Report Share Posted June 2, 2022 One of the first things I checked. All looks goodSent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted June 2, 2022 Report Share Posted June 2, 2022 Did you run a compression test on the left cylinder? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted June 2, 2022 Report Share Posted June 2, 2022 15 hours ago, jst854 said: Stock jugs Eric Gorr woods port. I haven't reached out to him regarding jetting as it was running well, thought I had it pretty close until whatever this is happened Sent from my ONEPLUS A6003 using Tapatalk I'd start there & see how far off you are if@ all Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted June 2, 2022 Report Share Posted June 2, 2022 Are the slides set to the same height on both carbs, or is one higher, and one lower? Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 2, 2022 Author Report Share Posted June 2, 2022 Yeah slides are the same height, carbs synced. Compression is good. 125ish on both sides. It runs well the 1st few seconds after I start it then it starts smoking a lot and is real boggy, won't idle, but won't die if you keep on the throttle will rev about 60-70% of the way out. If I shut off the fuel it runs well for a few seconds before it runs dry. Leads me to believe it is rich but I went from it running well with a 154 main and 50 pilot and now I have a 148 and 48 in it. Elevation and temperature no real difference between running well and this nowSent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted June 2, 2022 Report Share Posted June 2, 2022 Did you check the choke circuit to make sure the plunger is not hung up, causing a rich condition? Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 2, 2022 Author Report Share Posted June 2, 2022 Not sure, not very familiar with these carbs. I can pull the choke out and see through the passage on the side of the carb, besides that no. I take it just unscrew the choke and pull the whole thing out?Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted June 2, 2022 Report Share Posted June 2, 2022 Anything plugging the pipes or spark arresters? Quote Link to comment Share on other sites More sharing options...
jst854 Posted June 2, 2022 Author Report Share Posted June 2, 2022 Will double check that but shouldn't beSent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
machinegunbanshee Posted June 2, 2022 Report Share Posted June 2, 2022 Might also be time for a leak down test. Quote Link to comment Share on other sites More sharing options...
