Kev Posted May 1, 2022 Report Share Posted May 1, 2022 02 Yamaha banshee how is it possible for my gears shift opposite from factory? example: factory gears shift 1 down 5 up… problem now shifts 1 up 5 down.. how is that possible? All I did was put a new top end and this happens Quote Link to comment Share on other sites More sharing options...
Pinkylee Posted May 1, 2022 Report Share Posted May 1, 2022 Only way I can see that happening. Is if you somehow got the end of your shift shaft backwards. Where it connects with the shift star. Quote Link to comment Share on other sites More sharing options...
Kev Posted May 1, 2022 Author Report Share Posted May 1, 2022 Checked that and the gears it’s all Correct Illl heck the gears if they all in the right place I jus bought the bike and I dunno what the previous owner did Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 1, 2022 Report Share Posted May 1, 2022 So you bought it ( without riding it?) Put in a new top end, & now, with your new top end job done, it shifts backwards? Quote Link to comment Share on other sites More sharing options...
Kev Posted May 1, 2022 Author Report Share Posted May 1, 2022 Top end was blown yes it wasn’t running Quote Link to comment Share on other sites More sharing options...
IsaacL Posted May 1, 2022 Report Share Posted May 1, 2022 1 hour ago, Kev said: Top end was blown yes it wasn’t running I know it sucks to hear but the only way to fix it is to tear it all down yourself and rebuild it again. Only because that’s not a common problem so you might not find a solid answer. And if you’ve never rebuilt a full banshee motor, they’re really easy…just make sure you get the right center case gasket material and seal it up good. Plenty of videos out there too Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 1, 2022 Report Share Posted May 1, 2022 ^^ you can pull it aprt w/o Disturbing the top end . just strap the crank to the top case somewhere, and remove bottom half of case, while upside down... After you drive it around, like that 1st. to see if there's anything else you need to do while you're Tearing it down. pending Getting ahold of OG owner for possibilities of why, no strange noises during take off, & putting around... Quote Link to comment Share on other sites More sharing options...
Kev Posted May 1, 2022 Author Report Share Posted May 1, 2022 I’m in the process of tearing it back down ill keep posted cause this never happened before and I have rebuilt motors before Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted May 1, 2022 Report Share Posted May 1, 2022 Sounds like you didnt do it...keep us posted Quote Link to comment Share on other sites More sharing options...
