SHEEBANSAVAGE Posted April 12, 2022 Report Share Posted April 12, 2022 Hey guys, I have an 03 shee and it has FMF fatty’s with turbine core 2 silencers, uni filter, boyesene power reeds, stock air box, +4 timing plate. Stock motor. It’s been so long since I rejetted this thing cause most of my riding is at 3500ft. I can’t remember what I have in the carbs for jets. I believe I have 27.5 pilots, needle is middle position but can’t remember the mains. In a couple weeks I am making my first trip to the dunes in Oregon. What jetting should I set this banshee to? I will be running paddle tires as well. I’m planning on pulling the carbs tomorrow and rejetting Any help is appreciated. Thanks !! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sangheraent Posted April 15, 2022 Report Share Posted April 15, 2022 when are you going? I am from Abbotsford I will be there from the 29th of april for 4 days. for those mods probably a 310 main or a 320 main will do. I have a banshee with fmf pipes vforce reeds and a k&N its running 310 mains. I run the same jetting as here but you sound like your up north. Quote Link to comment Share on other sites More sharing options...
SHEEBANSAVAGE Posted April 15, 2022 Author Report Share Posted April 15, 2022 Thanks for the reply. I live in the lower mainland but the banshee is used up north at the family cabin. Ill be in the dunes after your trip is done. I did some research and called a couple places about jetting. Since I’m running stock airbox with lid on and a uni filter, I was told to run 280’s. They told me if I was running a K&N and no lid, run a 320. Does that make sense ???? Thx Again. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
sangheraent Posted April 21, 2022 Report Share Posted April 21, 2022 280s sounds a bit lean to me. personally I would run like 300s but i prefer a little rich on the mains especially when your on the sand full throttle for long periods. Quote Link to comment Share on other sites More sharing options...
SHEEBANSAVAGE Posted April 21, 2022 Author Report Share Posted April 21, 2022 Thanks for the reply. Since I already have the 280’s in already, I’ll give her a go and do a plug check on the first ride to see what it’s like. I have 300’s with me and ready to go. Cheers, Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dalton Posted April 30, 2022 Report Share Posted April 30, 2022 With those mods 280-300 for main. Clean your carbs with carb spray if you haven't done it in a while. Quote Link to comment Share on other sites More sharing options...
SHEEBANSAVAGE Posted April 30, 2022 Author Report Share Posted April 30, 2022 Thanks man. Carbs are clean!!Thx. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
