Southside Motorsports Posted December 18, 2003 Report Share Posted December 18, 2003 Is is true that reed spacers will give you more top end h.p. if used on the outside of your reed valves or is it better to not use them at all. Wicked ATV motorsports makes an intake manifold that appears to have the reed spacer built into but it is on the out side of the reed valve. Any advice would be appreciated I am currently running a 4.80 in 300ft. and am trying to get my times down. Quote Link to comment Share on other sites More sharing options...
flea49 Posted December 18, 2003 Report Share Posted December 18, 2003 This is just what i have heard from others,but you lose ponies if you place it,being the reed spacer against the cylinder,and gain a ponie or two if you place it between the reed and carb. Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted December 18, 2003 Author Report Share Posted December 18, 2003 I need more opinions guys.....help me out. Quote Link to comment Share on other sites More sharing options...
Dragg-on Posted December 18, 2003 Report Share Posted December 18, 2003 My builder said to ditch them on my drag motor. I dont know too much about them, I wouldnt use them cause they double-triple your chances of an airleak. and some say they add low end and response, but obviously you increase the distance from the carb to the cylinder, so I dont see how you get quicker response. Quote Link to comment Share on other sites More sharing options...
Screamin_Banshee Posted December 18, 2003 Report Share Posted December 18, 2003 My builder says ditch them as well, the only advantage I see to runnion them is if you have clearence probs with your big carbs. But then again, aftermarket intakes usually sure that problem as well. Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted December 21, 2003 Author Report Share Posted December 21, 2003 Thanks guys, I will get rid of the reed spacers. Quote Link to comment Share on other sites More sharing options...
SuCioDiFiciL Posted December 22, 2003 Report Share Posted December 22, 2003 what ? are you guys doin we in puerto rico use them .... reed spacers gives you more tork i dont know maybe you dont need them for sand but i say it helps Quote Link to comment Share on other sites More sharing options...
dunegoony Posted January 2, 2004 Report Share Posted January 2, 2004 by increasing the distance the carbs are from the reeds the more you increase velocity speed of the intake charge. The greater the charge the more torque you build. By increasing the distance of the reeds from the piston the better the throttle response you get.....more fuel/air in the engine. As far as air leaks.......use a lite film of ultra grey silicone on all surfaces if you are concerned Quote Link to comment Share on other sites More sharing options...
Dragg-on Posted January 3, 2004 Report Share Posted January 3, 2004 If a set of 1/2 inch spacers adds more torque, then what will 1 inch spacers do? Quote Link to comment Share on other sites More sharing options...
SHEEGUY SMOKEDYAA Posted January 3, 2004 Report Share Posted January 3, 2004 Experience from 250r bellow reeds made a lot of low end. Between reeds and carb made a smoother broader power band definatly noticed a differance. Same rules applied when put on banshee!!! Quote Link to comment Share on other sites More sharing options...
alocoholic Posted January 8, 2004 Report Share Posted January 8, 2004 Reedspacers more hp On the dyno no increase in hp or torqe.Dich the spacers.They will give you better throtle responce but will lower you crank pressure.If you dragging you don't want to lose no more than you have to.I've been building motors for years and the spacers is only a scame.You want more throtle responce invest in some ported reedcages and some dulestage reeds, or simply get some v-force.Something that will help you. Quote Link to comment Share on other sites More sharing options...
OlDsChOoLbLaStEr98 Posted January 19, 2004 Report Share Posted January 19, 2004 My builder says ditch them as well, the only advantage I see to runnion them is if you have clearence probs with your big carbs. But then again, aftermarket intakes usually sure that problem as well. I thank you should put them on. I Have one on my blaster and it works real good. Also I tried it next to the motor, and cage ( not much of a gain there). When i placed it between the cage and carb it showed some (Hp). I can see it maken the shee rip. Quote Link to comment Share on other sites More sharing options...
dlnoss Posted January 19, 2004 Report Share Posted January 19, 2004 There are differing opinions for sure. I sell 1/2", 3/4", and 1" reed spacers to one builder who builds some pretty mean drag motors, but I don't make any claims about them. Quote Link to comment Share on other sites More sharing options...
spoin39 Posted January 22, 2004 Report Share Posted January 22, 2004 I think they are like boost bottles. Alot of people like them and some don't but by the dyno charts I have seen on several sites they don't do anything. I have a boost bottle but I know it doesn't do a damn thing, but that was after I got it so it stays, plus looks better than the tube! Quote Link to comment Share on other sites More sharing options...
Southside Motorsports Posted January 25, 2004 Author Report Share Posted January 25, 2004 yesterday i went to my local dyno after my recent mods....and the first run i made 121.2 hp with nitrous in the first run and with the reed spacers and boost bottle....and took them off in the second run and it made 123.5 hp. Quote Link to comment Share on other sites More sharing options...
