Banshee_ Posted April 4, 2022 Report Posted April 4, 2022 Hi, i want some help with jetting my banshee toomey T5 cylinders light port work with extra drilled holes Stock carbs. Main jet 330 pilot 27,5 Toomey needles 3 notch from above vforce 4 reeds airbox with lid cut the inside of the lid no snorkel tors deleted sea level below 1 meter but when i drive to my moms city im like at 7 meters above sea level is my jetting good or is my jetting very off can you please let me know i just rebuild my topend and i dont want to screw it up thank you Quote
Dalton Posted April 30, 2022 Report Posted April 30, 2022 (edited) At sea level I was at a 350 main 30 pilot 3rd or 4th clip with my ported 4mil with pods....... so you are close. Experiment with different sizes for each position (pilot, needle, main) until you get the pull from the engine you like. Only do one position at a time though and one size at a time. Oh and one more thing...prior to doing any jetting take a can of carb spray and clean out all ports on carb especially the pilot. If it's dirty you will be chasing your tail all day. Edited April 30, 2022 by Dalton Quote
