Prime113 Posted March 8, 2022 Report Share Posted March 8, 2022 So I bought a throttle cable for my banshee because the old one was stretched out, found out after pulling slides out that the new cable didn’t have any threads on it to match the current carb caps I have on top of the carbs, will I need a new cable or should I order new caps? Not sure.Current tops of the carbsCloser view of cap, still not very visible but there’s threads on the top of it. Old cable, has threads to screw into the top of the carb.New cable, installed but wouldn’t fit and stay in carb caps because of it not having any threads on it. I’ve seen cables sold that have threads on them but they’re listed as cables for the TORS system, which my banshee doesn’t have anymore. Wondering if I need to buy new caps or a completely different cable. Thanks for any help I receive. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
kawa110 Posted March 8, 2022 Report Share Posted March 8, 2022 Purchase the motion pro tors elimination throttleCable kit. New cable, adjusters, and caps. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Prime113 Posted March 8, 2022 Author Report Share Posted March 8, 2022 2 hours ago, kawa110 said: Purchase the motion pro tors elimination throttle Cable kit. New cable, adjusters, and caps. Sent from my iPhone using Tapatalk Alright will do, thank you! Quote Link to comment Share on other sites More sharing options...
kawa110 Posted March 8, 2022 Report Share Posted March 8, 2022 So I have idle adjustment screws? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Prime113 Posted March 8, 2022 Author Report Share Posted March 8, 2022 Yeah my carbs have idle adjustment screws, I've played with them a bunch to get it to idle correctly, they would've gotten added in after tors was removed, right? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 11, 2022 Report Share Posted March 11, 2022 All you need to get is the threaded adjusters that screw into the carb tops and then the cable sits in the adjuster. Quote Link to comment Share on other sites More sharing options...
Prime113 Posted March 12, 2022 Author Report Share Posted March 12, 2022 17 hours ago, bansheesandrider said: All you need to get is the threaded adjusters that screw into the carb tops and then the cable sits in the adjuster. I ended up just buying the full motion pro kit with new cable, caps and adjusters. Havent had the chance to go out and work on it due to it either raining and being super windy, or just being too cold. Thanks for the help though! I guess I was just a little confused how the cable doesnt pull right out the top of the carb, but I didnt think it through properly. Quote Link to comment Share on other sites More sharing options...
