kawa110 Posted December 30, 2021 Report Posted December 30, 2021 Use some blocks and hold off on installing the shocks and youl save a lot of time with alignment.Sent from my iPhone using TapatalkUse blocks for desired ride height? Front and rear? Set alignment, then mount shocks. Don’t really know what I’m doing, printed off the write up you made. Plan to follow it. The fireball arms have adjustable upper arms at the frame. Makes for more fun. Sent from my iPhone using Tapatalk Quote
tfaith08 Posted December 31, 2021 Report Posted December 31, 2021 Use blocks for desired ride height? Front and rear? Set alignment, then mount shocks. Don’t really know what I’m doing, printed off the write up you made. Plan to follow it. The fireball arms have adjustable upper arms at the frame. Makes for more fun. Sent from my iPhone using TapatalkI know a lot more now than I knew then and I can probably help more on a case by case basis than that write up. Plus I’ll probably add to it in the future.I prefer to block everything to get to ride height and then set measurements, then bolt the shocks on and set them to ride height. Makes it much easier and faster.Sent from my iPhone using Tapatalk Quote
tfaith08 Posted January 1, 2022 Report Posted January 1, 2022 I just checked the scrub radius again and it really does seem the KPI is dead center. It totally makes sense, the different points of adjustment. I haven’t trigged everything out yet but with your write up and this thread, I am pretty confident I can make a decent project out of it.A lot of people seem to give up and convert their entire quad back to OEM or retrofit front ends from other quads. I’d rather set it up with what I have for a couple of reasons. Main reason: I already spent the money. But I’d like to know I can do it.I’m a tool and die maker so the math makes sense to me as well as picturing the results of certain adjustments. I appreciate all your help and time! Sent from my iPhone using TapatalkLol a lot of people either bolt it on and call it golden or they get lost in it and spend money unnecessarily. Also, no problem at all on the help and time. A lot of my effort in helping out goes back into trying to sift through gaps in what I know and understand. 4-5 years ago, I sat down and thought that I was a few ideas away from being out of things to learn about suspension. Now I’m one step away from a meltdown because of all the things I’m trying to figure out with it lol. Tool and die maker? I may have a few jobs for you at some point if you’re interested.Sent from my iPhone using Tapatalk Quote
Metal_man_Rob Posted January 1, 2022 Author Report Posted January 1, 2022 Lol a lot of people either bolt it on and call it golden or they get lost in it and spend money unnecessarily. Also, no problem at all on the help and time. A lot of my effort in helping out goes back into trying to sift through gaps in what I know and understand. 4-5 years ago, I sat down and thought that I was a few ideas away from being out of things to learn about suspension. Now I’m one step away from a meltdown because of all the things I’m trying to figure out with it lol. Tool and die maker? I may have a few jobs for you at some point if you’re interested.Sent from my iPhone using TapatalkAlways interested. I always have access to the shop when I am off the clock. Just depends on how involved it gets. I make tons of parts, build fixtures, jigs, gauges and progressive stamping dies. Piece work is always pretty easy.Sent from my iPhone using Tapatalk Quote
tfaith08 Posted January 1, 2022 Report Posted January 1, 2022 Always interested. I always have access to the shop when I am off the clock. Just depends on how involved it gets. I make tons of parts, build fixtures, jigs, gauges and progressive stamping dies. Piece work is always pretty easy.Sent from my iPhone using TapatalkShit yeah, I’ll send a PM.Sent from my iPhone using Tapatalk 1 Quote
kawa110 Posted January 2, 2022 Report Posted January 2, 2022 I know a lot more now than I knew then and I can probably help more on a case by case basis than that write up. Plus I’ll probably add to it in the future.I prefer to block everything to get to ride height and then set measurements, then bolt the shocks on and set them to ride height. Makes it much easier and faster.Sent from my iPhone using TapatalkPm sent Sent from my iPhone using Tapatalk Quote
