What Size Carbs Will Give Me The Best Bang For $
bigtreads
cruising ebay there seems to be alot of choices so I need some help figuring which will work best for me. My motor has PTR mid pipes piramid reeds/cages a 4 degree timing key Noss head with 21cc domes K&n filter with a drilled airbox lid. Stck carbs are currently jetted at 310's. I have no porting but by spring will have vitos pistons that give the effect of a light port job. I'm leaning tward a single carb but if I can get more action out of a set of duals I will do it. Any real world help greatly appreiciated. yes my 8 year old can spell better than me :rolleyes:
You will be surprised in the difference between 28's and stocker...IMO its little to none. The stock carb is VERY VERY under-rated. If it was me I would do like Minkia said, just get the stockers bored to a 27.5 or 28mm and save the money for other mods, or the always good alternative- BEER.
well part of my reason for trying a different carb setup is mine have some wear and the cables are shot. So if I have to replace the cables I gotta decide bettween the single carb or the duals. So if the 28's don't make much difference does the 30's ? Getting parts here is a pain so I mostly Ebay - there just happens to be some 30's on there at the moment so I was wondering. I like the idea of changing jet's easy - which was why I was leaning tward the single but apparently it's nearly as easy with the PWK's ??? thanks Norm
