Fr33zypop Posted July 27, 2021 Report Share Posted July 27, 2021 Earlier this spring I put in a new petcock as mine was leaking and this weekend I had a chance to to for a ride and while warming up the shee I could tell it wasn’t running well. I’ve come to to conclusion the gas isn’t flowing real well. When I removed the old petcock I found the plastic fuel filter has fallows off in the tank from a rollover or whatever from the last owner. I have a pretty new under 40 mile inline filter I’ve ran without issue on the old open petcock. I’m wondering if have two filters If it’s restricted. It’s hot af here so I plan to try and get a new inline and hose to see if that helps some early morning this weekend . I might try to drain the tank but I need a hand pump to see if the other filters the issue. The stem is bent in so I can’t remove the tank or petcock easily. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
