Fr33zypop Posted July 27, 2021 Report Share Posted July 27, 2021 Earlier this spring I put in a new petcock as mine was leaking and this weekend I had a chance to to for a ride and while warming up the shee I could tell it wasn’t running well. I’ve come to to conclusion the gas isn’t flowing real well. When I removed the old petcock I found the plastic fuel filter has fallows off in the tank from a rollover or whatever from the last owner. I have a pretty new under 40 mile inline filter I’ve ran without issue on the old open petcock. I’m wondering if have two filters If it’s restricted. It’s hot af here so I plan to try and get a new inline and hose to see if that helps some early morning this weekend . I might try to drain the tank but I need a hand pump to see if the other filters the issue. The stem is bent in so I can’t remove the tank or petcock easily. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Keno Posted July 27, 2021 Report Share Posted July 27, 2021 Ditch the inline filter and clean your tank. Just take the tank off and clean it out. Super easy. Quote Link to comment Share on other sites More sharing options...
