Ronniethebigman Posted July 7, 2021 Report Share Posted July 7, 2021 I have j-arm spindles . was wanting to know if the yz450 brakes would work on the j-arm spindles or do I just get a-arm spindles and go from there my brakes are also j-arm style but are in vary bad shape. do they still make rebuild kits or aftermarket brakes that fit the j-arm style spindles Quote Link to comment Share on other sites More sharing options...
kawa110 Posted July 7, 2021 Report Share Posted July 7, 2021 All balls rebuild kitsSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Ronniethebigman Posted July 7, 2021 Author Report Share Posted July 7, 2021 20 minutes ago, kawa110 said: All balls rebuild kits Sent from my iPhone using Tapatalk so the 1990 and up rebuild kits will rebuild the 1989 j-arm brakes? if not which rebuild kit do I get? is it just the way the brakes are mounted on to the j-arm spindles that are different from the a-arm setups Quote Link to comment Share on other sites More sharing options...
kawa110 Posted July 7, 2021 Report Share Posted July 7, 2021 From what I know(which isn’t much) it’s just the spindles mounts and calipers mounts that are different. The caliper “guts” should be the same. But I could be wrongSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted July 8, 2021 Report Share Posted July 8, 2021 Caliper guts should be the same. 1990 Banshees had the A-arm style brakes on the J-arm suspension. Quote Link to comment Share on other sites More sharing options...
