What is needed for 4 mil serval?
Multiple questions here:
As this quad is restricted almost exclusively to forested mountain trails with ruts, rocks, roots, wash outs, mud, hills, bumps, curves, etc, I want to build a banshee as well suited for trails as possible.
The following are questions that’ll help me purchase what I need for a winter build project. I will be ordering parts starting soon.
1. Should I build Stock bore, 392 or 421?
2. Serval good or is there better for trails?
3. Dome size best suited for trail riding, reliability and pump gas?
4. Are driveline kits decent?
5. Clutch build advice?
6. Will the stock transmission be good enough? Or what should be done to make it solid.
7. 33mm carburetors a decent size for the above mentioned bores? How do I determine carb size needs for the build?
8. The current engine is stock. I was told it has an advanced curve 4 degree timing plate but it looks like a stock plate. Is there other methods to advance timing other than adjustable plate?
9. What cool head seems to be the most tried and true
10. Any other advice, things to buy, watch out for etc?
