Banshee radiator swap
Buy an oversized radiator, any after market impeller as long as it has a hardened shaft. Run water mixed with enough coolant additive to prevent any galvanic corrosion ( I believe its like 15% for most additives)
Ensure that you are not detonating any, as that can spike temperature.
2 hours ago, Timcon said:
its is highly overpriced in my area sells for 300 dollars while the other one is 150
is it worth it?
probably not. i run the cheap ebay rad and have not had issues. they are pretty simple setups, save the money and spend it on something else.
