Probably won't affect the mains...if anything I'd guess you might need a size smaller (aftermarket reeds sometimes make it run richer). But I'd try it with the mains you have now.
BTW you might need to move the needle a clip position leaner (usually) or richer (in some cases), depending on how it runs from about 1/4 to 3/4 throttle, and you might need a richer pilot, depending on how it responds right off idle (if going out on the airscrews helps but it still hesitates). Good luck.
When I put my V-forces on I went up one size on the main and went 1/2 notch richer on the needle (used the needle washers under the clip). Mine ran great w/this combo.
