Banshee switches back and forth running on one cylinder
Hi guys looking for info because i am at a loss. My banshee was running great one day then the next it runs like sh*t
Symptoms: Will not idle, basically running on one cylinder but switches back and forth on which cylinder it wants to run on. No power what so ever until very high rpm both cylinders come together. Let out of throttle it will stall.
What I have checked: compression good 135psi, has good blue spark both sides, flywheel and key look good in place. stator ohms are within spec. Replaced cdi box with used oem, carbs have been cleaned and gone through and is getting good fuel. Replaced ignition coil, wires caps. Wiring harness looks good have not gone through that yet. Reeds look good they are not broken or bent.
Nothing I have done has made a difference. Could it be something with the kill switch? I'm out of ideas if anyone has something to say I'm all ears. Thanks
