Won’t start
^^^^ what he said lmao. when you "killed it " did it bog down and die/ something else. or did you just stall it? usually if it starts with a rolling/pull start but not with a kick. its a sign of low compression. i would also check to see that you don't have a bad ground somewhere. ( pull on the wires at the back of plugs check harness etc.) try new spark plugs because it could have spark but still not be enough to start.
