caleb90 Posted April 26, 2021 Report Share Posted April 26, 2021 getting my shee back together slowly and had some jetting questions. 4mil crank, fast dune/play port, vforce 4s, 23cc domes,plus 4 timing, fmf fattys but will be slp's once they come in. running stock carbs with air box no lid and pro flow adaptor. Jeff wants me to start at 350 mains , needle clip full rich with 30 pilots. im at 1400ft elevation. whats your thoughts? Quote Link to comment Share on other sites More sharing options...
gusto Posted April 26, 2021 Report Share Posted April 26, 2021 He is starting you off high on the main which is safe. Your pilot shouldnt change, your main jet will drop no doubt until you find the sweet spot. Buy some jets and plugs and get testing. I bought the Driveline oversized bowls with easy access to the main like a Kehein carb. Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 26, 2021 Author Report Share Posted April 26, 2021 we will see, all ready dreading pulling the bowls off every time. before i spent 110 bucks on bowls id just invest in some 28mm pwks Quote Link to comment Share on other sites More sharing options...
gusto Posted April 27, 2021 Report Share Posted April 27, 2021 Buy a JIS (Japanese industrial standard) screw driver for those shit screws on the bowls Quote Link to comment Share on other sites More sharing options...
Keno Posted April 28, 2021 Report Share Posted April 28, 2021 On 4/26/2021 at 7:12 PM, gusto said: Buy a JIS (Japanese industrial standard) screw driver for those shit screws on the bowls THIS. Best investment in a tool I've made in a while. Bought a Vessel +2 screwdriver several years ago, use it constantly. Quote Link to comment Share on other sites More sharing options...
gusto Posted April 28, 2021 Report Share Posted April 28, 2021 Same, I bought three vessels. It’s a legit big difference than using a Phillips Quote Link to comment Share on other sites More sharing options...
caleb90 Posted May 3, 2021 Author Report Share Posted May 3, 2021 as off right now the 30 pilots are extreamly fat Quote Link to comment Share on other sites More sharing options...
seansy007 Posted May 3, 2021 Report Share Posted May 3, 2021 2 hours ago, caleb90 said: as off right now the 30 pilots are extreamly fat how much have you ran the bike? i know after rebuilding bikes they are extremely rich till they get ran through the gears in the powerband and cleared out then do a lot better. 30 pilots shouldn't be that rich but if you're sure drop it to 27.5. Quote Link to comment Share on other sites More sharing options...
caleb90 Posted May 4, 2021 Author Report Share Posted May 4, 2021 19 hours ago, seansy007 said: how much have you ran the bike? i know after rebuilding bikes they are extremely rich till they get ran through the gears in the powerband and cleared out then do a lot better. 30 pilots shouldn't be that rich but if you're sure drop it to 27.5. i havnt rode it yet.. just 3 heat cycles varying throttle while in shop. we will see how it is after i ride it and blow it out Quote Link to comment Share on other sites More sharing options...
