caleb90 Posted April 25, 2021 Author Report Share Posted April 25, 2021 5 minutes ago, 375hp banshees said: Can you swap the joints top to bottom? Are they different lengths? top n bottom joints are completely different. cant swap Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 25, 2021 Report Share Posted April 25, 2021 Guess you'll have to ask alba or there #1 fan...mr cLaRkSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 25, 2021 Author Report Share Posted April 25, 2021 his proclaimed love for them is what sealed the deal for me to buy them Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 25, 2021 Report Share Posted April 25, 2021 He likes little boys too... just say'n Quote Link to comment Share on other sites More sharing options...
dano3 Posted April 25, 2021 Report Share Posted April 25, 2021 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gusto Posted April 26, 2021 Report Share Posted April 26, 2021 So your maxed out also? I guess maxed out is good enough. caleb you look like you have 4-5 degrees now, what about when you sit on it? If it’s 3-5 degrees run it Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 26, 2021 Author Report Share Posted April 26, 2021 10 hours ago, gusto said: So your maxed out also? I guess maxed out is good enough. caleb you look like you have 4-5 degrees now, what about when you sit on it? If it’s 3-5 degrees run it according to my digital protractor, the camber is 1.50 unloaded and about .45 .50 with rider weight Quote Link to comment Share on other sites More sharing options...
dano3 Posted April 26, 2021 Report Share Posted April 26, 2021 So your maxed out also? I guess maxed out is good enough. caleb you look like you have 4-5 degrees now, what about when you sit on it? If it’s 3-5 degrees run itMine has room to go but it appears I have more camber than he does. I dont remember the exact #s, would have to measure again. Out upper ball joints seem to be close to the same location assuming they are the same. I have about 4-5 threads exposed past the lock nut. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 26, 2021 Report Share Posted April 26, 2021 I'm confused.. Which way do they need to go? By looking at the pics, you need to screw the ball joints out more. Mine have 1/8" of camber at the top when resting. Quote Link to comment Share on other sites More sharing options...
dano3 Posted April 26, 2021 Report Share Posted April 26, 2021 Just measured mine at -2.5-3* camber. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 27, 2021 Author Report Share Posted April 27, 2021 noticed how my lower mounting point is welded crooked compared to dano3's. that right there can make a huge differenceSent from my SM-G920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 27, 2021 Report Share Posted April 27, 2021 Yeah that joint's already on a hellofa angle @ ballSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 27, 2021 Author Report Share Posted April 27, 2021 proof in da puddin.. this is with rider weightSent from my SM-G920V using Tapatalk Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted April 27, 2021 Report Share Posted April 27, 2021 Pull the bottom out some & you'll be perfect Quote Link to comment Share on other sites More sharing options...
caleb90 Posted April 27, 2021 Author Report Share Posted April 27, 2021 2 hours ago, 375hp banshees said: Pull the bottom out some & you'll be perfect ya cant with these arms. staying as it is, done dickin with it.. china joe ftw 1 Quote Link to comment Share on other sites More sharing options...
