seansy007 Posted April 28, 2021 Report Share Posted April 28, 2021 (edited) id check to make sure the basement isn't flooded on it. id also try running g a ground to the cylinders/frame/cases. seems like you've checked most of the stupid stuff. I would try a differe.t set of reeds aswell. I've had bad ground from stator to cdi cause runnability/bogging problems. (stator plug ground wire started coming out back of plug) Edit: usually anything electrical can be followed which it seems yours can't be so I would assume its a mechanical problem. Edited April 28, 2021 by seansy007 add info Quote Link to comment Share on other sites More sharing options...
ride.race.live Posted April 29, 2021 Author Report Share Posted April 29, 2021 Yeah Claude I saw the videos everything seemed spot on except when he mentioned the plug tolerances being 5-10k. didnt make sense to me. Ill try adding a ground from the motor to the frame and see how that goes as well! Seansy when i took out the VF3 reeds and re installed the stock reeds i inspected the bottom end and there was no abnormal amount of fuel down there. (so ive tested 2 separate reed cages) i can double check the wire harness but it is a brand new harness for South Texas Banshee. Quote Link to comment Share on other sites More sharing options...
