Metal_man_Rob Posted March 26, 2021 Report Share Posted March 26, 2021 My right carb is junk. Allows fuel past the float valve o ring, no matter what I do. New valve, o ring, different o ring, bigger prong, old valve, new valve, switched valves, etc. Fu*k this carb. -stock motor-stock timing (although I just got an adjustable plate I need to install)-Have a pro flow air box mod with a k&n filter-vforce4 reed valves (I know... not necessary)-stock exhaust -600ft elevation-40:1 yamalube 2R-riding exclusively XC style. All forest trails, rocks, mud, branches, shit 4x4s are made for but fun AF on a banshee. Current carbs are mikuni VM28. I can go back to Mikuni stock carbs, dual Keihin 28mm carbs, a 1 into 2 single carb kit with pods or air box, lectron single 36HV or dual lectron 30s. Either way I want to make one purchase on this one. If Keihin, I know absolutely nothing about Keihin jetting. Where to start with one 35mm or two 28mm. So anybody have a couple cents on this one? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
