banshee oil mix
Timcon
14 hours ago, Timcon said:
will it affect my banshee if I used 25 liters to 2 ratio?
Changing oil mix ratio will mean you'll need to retune your carbs. If you were running a 40:1 but then mix at 32:1, you'll run lean and won't burn off the oil in the mix. Your plugs will be soaked in oil and your expansion chambers will pool up with oil. Mostly you'll fry your top end from running that much more lean. The oil is only there for lubrication. It helps protect against higher performance mods when going to a richer mix but the added oil isn't going to add performance. And if you don't jet for the leaner or richer condition (depending on what you want to switch from), you'll screw your top end.
That's what I read twitter
