Spark plug White ceramic moving up and down in metal shell
Jackham
99 RON is like 93 AKI? Octane booster is usually trash. And your compression is probably around 180 psi? I would keep timing stock and run a wide squish.
Replace the plug and suspect deto if it happens again or your plugs keep backing out. You could try richening your main a bit to lessen the chances of deto.
Other option is to put some 23cc domes in.
