Azssminnow Posted January 12, 2021 Report Share Posted January 12, 2021 Current mods are: paul turner mids w fat boys milled head (not sure how much but it clearly is when I compared it to a factory) timing plate vforce reeds (look like older ones) factory carbs jetted w pods I ride desert mainly.. if you had say 3-5k to throw at this power wise.. what would you do? also, any recommendations on who to contact for the build thanks Quote Link to comment Share on other sites More sharing options...
Sully78 Posted January 12, 2021 Report Share Posted January 12, 2021 Call cam at redline and thank me later. Very reasonable and does fantastic workSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Azssminnow Posted January 13, 2021 Author Report Share Posted January 13, 2021 Will do.. thanks Quote Link to comment Share on other sites More sharing options...
kawa110 Posted January 13, 2021 Report Share Posted January 13, 2021 Suspension Quote Link to comment Share on other sites More sharing options...
SKEETER Posted January 13, 2021 Report Share Posted January 13, 2021 2500 in suspension, 2500 into motor. Tell cam what you got to spend, and what you do, he'll set you up. Dont send him used underwear , it's a trick. Quote Link to comment Share on other sites More sharing options...
gusto Posted January 13, 2021 Report Share Posted January 13, 2021 If I had 3-5k I’d put 1k into the engine and put the rest into suspension and a desert tank. 4 mil stocker or just a plain port job with welded crank would be a big power improvement. HJR play port or dune port Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted January 13, 2021 Report Share Posted January 13, 2021 Absolutely suspension. Swingarm, a-arms and shocks. Quote Link to comment Share on other sites More sharing options...
Azssminnow Posted January 13, 2021 Author Report Share Posted January 13, 2021 Already have alba long travel a arms with ELKA Front and rear.. plus many other mods.. im asking specifically about motor.. thanks for the input guys! Quote Link to comment Share on other sites More sharing options...
gusto Posted January 13, 2021 Report Share Posted January 13, 2021 (edited) Is gas mileage a factor? Edited January 13, 2021 by gusto Quote Link to comment Share on other sites More sharing options...
pp13bnos Posted January 13, 2021 Report Share Posted January 13, 2021 Another vote for the weirdo at Redline. He's done my wifes and I banshees, my kids lt80, and my yxz. All of them run super hard, and are reliable. Quote Link to comment Share on other sites More sharing options...
Azssminnow Posted January 13, 2021 Author Report Share Posted January 13, 2021 Fuel mileage.. not really. I don’t race. I just ride around the house because I live in the middle of nowhere. I imagine I’ll get a high capacity tank if need be.. I assume redline will know what carbs and what not to run with his build. I just don’t want to be throwing parts at this thing to see what works. Prefer to just do it right the first time.. Quote Link to comment Share on other sites More sharing options...
gusto Posted January 13, 2021 Report Share Posted January 13, 2021 I would go with a Serval or low port Driveline set up. Go with a 421. My engine is in the dyno section if you want to look at what that set up can get you hp wise. A builder like Redline or Driveline knows the formula for their engines so they can set you up all the way. Youll need a pro mod transmission and billet clutch basket for the extra power along with the internal mods like high flow impeller, pancake bearing etc. 2 Quote Link to comment Share on other sites More sharing options...
WALZ Posted January 13, 2021 Report Share Posted January 13, 2021 Pro mod 4 hours ago, gusto said: I would go with a Serval or low port Driveline set up. Go with a 421. My engine is in the dyno section if you want to look at what that set up can get you hp wise. A builder like Redline or Driveline knows the formula for their engines so they can set you up all the way. Youll need a pro mod transmission and billet clutch basket for the extra power along with the internal mods like high flow impeller, pancake bearing etc. Pro mod makes trans stronger? How would removing every other dog ear be stronger? Quote Link to comment Share on other sites More sharing options...
gusto Posted January 13, 2021 Report Share Posted January 13, 2021 The transmission as it is is plenty strong, the problem with the increased hp is the shifting. The promod eliminates that problem so shifting under load is easier. 1 Quote Link to comment Share on other sites More sharing options...
