luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 1 minute ago, the boris said: What height is your needle set up at? Sent from my VOG-L29 using Tapatalk so i just seen the ebay post i bought the rebuild from pilot is 30 and needle that i have no clue i never mess with those since im not sure what to do with that Quote
hoppedupandcutdown Posted January 10, 2021 Report Posted January 10, 2021 So you're positive the slides aren't in backwards? What is your elevation in feet? Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 7 minutes ago, hoppedupandcutdown said: So you're positive the slides aren't in backwards? What is your elevation in feet? i dont think so cause the slides fall all the way in i gotta check that tomorrow since its getting dark ill keep you guys updated Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 39 minutes ago, hoppedupandcutdown said: Maybe your not getting enough air, so it runs better with such a small main, Stock pilots are 25,Sorry I didn't understand your previous post. wait so are both supposed to face each other or no or both facing the air filter ik sounds dumb but i wanna make sure 1 Quote
the boris Posted January 10, 2021 Report Posted January 10, 2021 wait so are both supposed to face each other or no or both facing the air filter ik sounds dumb but i wanna make sure When you take air filter out and look at them the side that is circled green should be facing you. Sent from my VOG-L29 using Tapatalk Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 7 minutes ago, the boris said: When you take air filter out and look at them the side that is circled green should be facing you. Sent from my VOG-L29 using Tapatalk so pointing toward the airfilter got it ill check that early in the morning 1 Quote
gusto Posted January 10, 2021 Report Posted January 10, 2021 How’s the condition of your reeds? Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 3 minutes ago, gusto said: How’s the condition of your reeds? reeds look fine not too bad on them Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 4 minutes ago, gusto said: How’s the condition of your reeds? nothing too bad i mean like they look good condition but kinda old Quote
gusto Posted January 10, 2021 Report Posted January 10, 2021 If they are chipped or you can see daylight through them that will cause problems.So your saying it’s so rich that the plugs are soaked when you pull them? Sent from my iPhone using Tapatalk Quote
luna2001xx Posted January 10, 2021 Author Report Posted January 10, 2021 1 hour ago, gusto said: If they are chipped or you can see daylight through them that will cause problems. So your saying it’s so rich that the plugs are soaked when you pull them? Sent from my iPhone using Tapatalk no my plugs when i pull them are nearly dry but burnt Quote
gusto Posted January 11, 2021 Report Posted January 11, 2021 You should check your compression. if your plugs are brown and not wet or black or white your jetting might not be a problem Quote
Mix-gas-haul-ass Posted January 17, 2021 Report Posted January 17, 2021 Have you checked your float level? I know that that can cause some issues with trying to jet correctly. Quote
