2006 banshee power
GoatHzb
Gearing for low end will mean you sacrifice top speed. You also need to balance power and traction. Stock gearing is actually quite good for most riding. If you want more low end go down a tooth on the front sprocket or up a couple of teeth on the rear sprocket. There is a gearing calculator in the tech info section
