Banshee blew
JesseDR
How sure are we that it was an air leak?
I've been dealing with this pretty regularly. 4 rebuilds... all within a couple of hours or less of riding. Every rebuild requires new cases and crank as well as cylinders refurbished. Im honestly thinking that its a loss of fuel. Im to the point where I dont think the hole in the fuel cap is drilled out big enough.
What was the reason for the top end rebuild before it happened? Was the crank and rods properly inspected while it was apart? Did the crankcase get properly cleaned out of all foreign material during the top end job? At the minimum, you are going to need a new or rebuilt crank assembly, all the gaskets and seals, and redo the top end. Make sure you get the crank welded while you are in there. Inspect your cases very thoroughly , replace anything else that is worn or damaged. Don't cheap out on anything, use good quality parts and fix everything so you don't have more failures and collateral damage.
