Jocelyn lapointe Posted December 22, 2020 Report Share Posted December 22, 2020 I have buy a alloyboltz complete stainless steel bolt kit and wonder if anyone use the bolt instead of the stud for closing de case? I have a CPI SERVAL 421 and want to know how much timing advanced I need with pump gas(cool head 24cc dome)? I have a trail tech vapor and want to kkow the best method to have an accurate RPM? Probably already answer somewhere else but I can't find it... Is something can be done to make the stator more reliable? From what I read stator are know to gone bad! Thank you for your time Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted December 22, 2020 Report Share Posted December 22, 2020 I have buy a alloyboltz complete stainless steel bolt kit and wonder if anyone use the bolt instead of the stud for closing de case? I have a CPI SERVAL 421 and want to know how much timing advanced I need with pump gas(cool head 24cc dome)? I have a trail tech vapor and want to kkow the best method to have an accurate RPM? Probably already answer somewhere else but I can't find it... Is something can be done to make the stator more reliable? From what I read stator are know to gone bad! Thank you for your time Pour le timing, +4 est généralement la "norme" sans avoir de problème.Pour le rpm, normalement tu as juste à te connecter sur le fil jaune.Envoyé de mon SM-N975W en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
97Screamer Posted December 22, 2020 Report Share Posted December 22, 2020 Use the studs with nuts on the lower cases, same with cylinder to cases and cylinder to head. +4 timing is safe for most applications. I don't use trail tech but wrapping the rpm wire securely around the coil wire has always worked fine for me. Quote Link to comment Share on other sites More sharing options...
