Ran fine and started 1-2 kicks when it came into the state, but after about an hour of on and off of ride time it became fussy and didn't want to idle well and then began popping from the exhaust when trying to kick it over, which led me to believe the jetting is off. Currently has 280 mains. This is my first time pulling the carbs off, cleaned them thoroughly and waiting to put the 27.5 pilots in and going to see if she fires.
Helpfully that'll take care of it, make sure you put the Correct bowl, on the Correct carb. They will fit either one, but won't start/run right if wrong. And as Mentioned, make sure crossover tube is put back on
Sent from my SM-A505U using Tapatalk
Got the chance to put the new pilot jets in and put everything back together last night, she fired up second kick and has a perfect idle with those 27.5 pilots! I also moved the needle clip to 4. Not sure what the problem was, maybe dirty carbs...not sure... but she sounds really good now and rips like hell. I really appreciate everyone's help on here!
