clutch cover
caleb90
this is my first time tearing into a banshee. first the clutch boss is scuffed up on the outside. i couldnt see what could have been rubbing it, possibly from clutch tool from previous clutch replacment? second the kick gear on the stub shaft with the c clip has a bunch of side play, normal?06bb4aa1bc3329bb330b97bbcdef5d28.jpg
Sent from my SM-G920V using Tapatalk
43 minutes ago, caleb90 said:
not the kickern but the kicker idle gear. after removing it the bushing is worn.. research shows me this is a common problem
Yes, it is, the bushings are cheap to replace
On 12/4/2020 at 11:48 PM, caleb90 said:
pulling my motor apart. any bracket supposed to go over breather hose?e625ea01dc92a90e54753716428eaa7d.jpg
While your in there you could block off this breather and plug the hole for the hose with some black silicone. It was used for the 2t oil  pump on the rd/rz 350. The brass nipple presses out (from the outside in) you can make or buy a block off plate that screws in to those 2 holes. It’s not necessary but it’s a much cleaner set up.
-Ben
