Weston_ Posted December 1, 2020 Report Share Posted December 1, 2020 I have a 94 banshee , Cool head pistons that where bored over running 150 psi on both cylinders, toomey pipes, Bulls eye reeds, hot rod crank, full bore radiator, a couple of other things , i have no other ideas on what has been done to this quad from the guy a i bought it from, im looking for someone really experienced on banshees. We run 300 jets in it and a size pilot jet i would have to look. We rebuilt the carbs, got them as clean as possible, and new gaskets, would put it all back on, and we fire it up, and the carbs start leaking out of the overflow, we have the idle screws all the way maxed out for it to barley stay idling, is still not getting enough gas, and wanting to bog out,can anyone thats very good on carbs give me some advice will be much appreciated. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 1, 2020 Report Share Posted December 1, 2020 Stock carbs w/ tors delete? Bosses probably werent shaved to make them go deeper before bottoming out look here for over flow issuehttps://www.bansheehq.com/forums/index.php?/topic/192426-carb-replacement/Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 1, 2020 Author Report Share Posted December 1, 2020 Do u have any advice on it bogging out, we have the idle screws maxed out and its still barley wanting to idle? Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 1, 2020 Report Share Posted December 1, 2020 Remove the lock nut (temporarily ! ). screw in farther & see if that helps.Then either shave boss down more > or adj. idle by the cableSent from my SM-A505U using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 1, 2020 Author Report Share Posted December 1, 2020 I have another question, we are in 50 F weather, what size pilot and main jets should i be runing with the mods i listed above, this is are main problem Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 2, 2020 Author Report Share Posted December 2, 2020 (edited) Yes right now im running air box/no lid with K&N, Im riding at sea level. I just dont understand why they keep leaking with them all cleaned and rebuilt and a new gasket. Im guessing that that is making it not want to idle. They are 28m mikuni carbs Edited December 2, 2020 by Weston_ Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 2, 2020 Report Share Posted December 2, 2020 It's leaking out the overflow right? Did you check off the stuff on the link i posted... did you put a new needle and seat with sealing ring, inspect float & set properly, fuel cap vents properly, check for leak with bowl off...? Turn the fuel off ( or open drain) to keep level below overflow tube & see if it runs better with out over flowing?Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 2, 2020 Author Report Share Posted December 2, 2020 Thank you, iwill try all of this, yes i looked on the site, and do u get a notification when i reply? if i do later on so i can get back with you. Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 2, 2020 Author Report Share Posted December 2, 2020 And this is a mistake on my part, as saying overflow, i meant in the seal where the gasket is when u take it off, the gasket is in there perfectly, and screws are tight. I dont understand why it would be spitting out gas, theirs no dent or bruise in it. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 2, 2020 Report Share Posted December 2, 2020 Thats a whole different problem Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 2, 2020 Author Report Share Posted December 2, 2020 Well, do u have a Instagram or messenger i can talk to you on besides this. Quote Link to comment Share on other sites More sharing options...
SKEETER Posted December 2, 2020 Report Share Posted December 2, 2020 He prefers home calls, after 830pm PST. Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 2, 2020 Report Share Posted December 2, 2020 ^^ or. HMFICdontsteelmysheepics@shirmpbansheez@instahgram.clarkSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Weston_ Posted December 3, 2020 Author Report Share Posted December 3, 2020 So the only way to get that right is to buy a new carb Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted December 3, 2020 Report Share Posted December 3, 2020 Check your pm'sSent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
