Dezjvuw Posted November 23, 2020 Report Share Posted November 23, 2020 So I got a banshee with stock airbox. I recently installed the K&N air pods with outwear and now its running really rough and won't hit the power band. I took them off and tried it without filters and its a beast again. I installed them again and same problem but this time I tried pushing it to the power band and it sucked so much air that the filters collapse and I dont know why its not working right. I seen alot of people use this without problems. Any suggestions or help would be appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
375hp banshees Posted November 23, 2020 Report Share Posted November 23, 2020 Filters over oiled, did you re jet for pods?Sent from my SM-A505U using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dezjvuw Posted November 23, 2020 Author Report Share Posted November 23, 2020 So the filters were installed straight from the box to the carbs. Also the carbs did not get any new jetting. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 27, 2020 Report Share Posted November 27, 2020 Outerwares plug up and cause this issue. I don't see any reason to run them unless you're in the sand, where you will find little to no dust. Quote Link to comment Share on other sites More sharing options...
