Help with FTZ battery ignition system
El Bori
Help please
I have a FTZ battery ignition system set up in my banshee was running good but I did a transmission rebuild and forgot to mark the trigger wheel in the crankshaft for the install position. This set up does not use a woodruff key to install the trigger wheel back in the crankshaft so I am not sure which position to install back on. I am pretty sure that has to have a correct position in the crankshaft do to timing so will tell the MSD box to fire correctly. I try to call FTZ for technical advice or instructions an no luck told me the set up was to old they have no clue.
